transmission and pinion shaft mis-alighnment - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2013, 12:32 AM
Now that I have my frame done and the rear 4 bar suspension and axle installed, I discovered that my welder installed my 4 bar axle brackets one inch and an eighth to the left. Now that my pinion is one and an eighth inch to the right of center, begs the question among others. Does the trans. shaft and pinion have to line up straight on laterally or is there an excepted amount of ms-alignment ?
I measured from end to end for the degree angle, and it came out 1.5 degrees.
I could move the drive train over to the right this amount, but buying new brackets and having them re-welded would be less of a hassle.
Your help here would be greatly appreciated, Thanks, Gary
Old 05-25-2013, 05:30 AM
BOBCRMAN@aol.com's Avatar
Should not be a problem. Ford motor company has used offset pinion rear ends since the fifties with no bad effects.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
GARY HOOTEN (05-26-2013)
Old 05-25-2013, 07:19 AM
Wiki Edits: 27
Ford GT ?
The first new Ford Gt ( Modern version of the old GT 40 ) had the rear of the body tilted up and the rear half shafts have a lot of off set from the Dif out to the wheels. I was used to looking at corvette and Jag Irs and spotted it right away.
The Following User Says Thank You to timothale For This Useful Post:
Old 05-25-2013, 07:54 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
No idea why this is in "site suggestions & help" forum... moving to basics forum
The Following User Says Thank You to Crosley For This Useful Post:
Old 05-25-2013, 08:16 AM
The output shaft and pinion shaft are offset up and down normally. There's no difference between an offset in that direction and an offset side-to-side. What IS important is that the two shafts need to be parallel.
The Following User Says Thank You to joe_padavano For This Useful Post:
Old 05-25-2013, 08:18 AM
Is the rear end centered in the frame? How in the living hell does someone do this, does he not have a measuring tape? You should buy him a measuring tape so he doesn't do this to the next guy.
The Following User Says Thank You to MARTINSR For This Useful Post:
Old 05-25-2013, 08:23 AM
S10xGN's Avatar
Gotta love a turbo!
I'd be more concerned about the tires being offset than the pinion. Neither will "hurt", but one will look like dammit while the other will never be seen...
Russ
The Following User Says Thank You to S10xGN For This Useful Post:
Old 05-25-2013, 09:34 AM
1971BB427's Avatar
No reason to get excited. Even a couple inches right or left wont mean a thing. If it was an issue, then you couldn't have a driveline that ran uphill to the trans either. As mentioned, stock Fords have been this way for many decades.
The Following User Says Thank You to 1971BB427 For This Useful Post:
Differentail pinion shaft offset ? supercab78 Hotrodding Basics 6 10-21-2012 06:03 PM
Pinion shaft bearing? chevyrally68 Transmission - Rearend 4 11-29-2010 03:13 PM
Off-set Pinion Shaft dchatcher Transmission - Rearend 25 05-12-2009 07:39 PM
Question on 700r4 transmission tail shaft and front shaft eric32 Transmission - Rearend 11 05-10-2009 12:03 PM
Pinion Shaft retaining bolt 67 Hugger Transmission - Rearend 3 03-22-2004 06:50 PM
