transmission problem turbo 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2003, 07:23 PM
jester429's Avatar
I was taking off the shifter arm on the side of the transmission so i could adjust the cable a little tight and while removing the arm the whole piece began to spin including the pin going into the transmission so now it won't shift and im stuck any ideas?
Old 10-04-2003, 07:34 PM
BOBCRMAN@aol.com's Avatar
Drop the pan and you will find a nut on the other end of the shaft, this holds the selector lever tight to the manual valve linkage, it's probably loose.
