Transmission problems
so my 700R4 blew out on me... but I do have a T350 that was rebuilt a few years ago. the only problem is it's out of an 81 camero.. and the speed sensor is a cable not electronic like in my 89 S10 4.3 so i was wodering if i could swap the tailstocks and have my speed sensor work. also will the flexplate and torque converters holes align so it will bolt up? thanks any help would be appreciated
Last edited by DaleMcD; 12-01-2006 at 04:45 PM. Reason: guy told me it was from a van when it's accually from a 81 camero |
Check out this web site www. geocities.com/crosley az/700id.htm
Or go to page 3 of this site,look for 700id,then you can just clik onto site,to find above site. |
no & yes You need a 9 inch tail housing on the t-350 to replace the 4L60 trans in the S10 to get a tranny of the same length..... this is a 2 wheel drive vehicle? Or are going to have the drive shaft modified? 700/4L60 tail housing is about 1 & 3/8 inch longer than a 6 inch tail housing from a t-350 tranny The converter bolt pattern on the flex plate will work from the 4L60 / 700 trans to the t-350 converter.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Tranny problems
Thing is i'm a student and money is tight i'm jsut trying to get my truck on the road with what i have and the cheapest way possible.
the th350 is too short, by 3"
if it wasa truck th350 then it would work, 73-up anyways 69-72 all were 6" tail 73-up truck th350 were 9" tail cars except some wagons are 6" tail some wagons were 12" tail but rare/uncommon good luck |
Tranny
so i bit the bullet and bought another 700R4 from a local salvage yard... $300(canadian) with 120K on it not bad I think just have to put it in and wish for the best
Change the fluid, filter....and put in a new front seal while it is out.
Ontario Rodders |
tranny
the fluid and filter will be changed right away but could you give me an idea on how to change the front seal please i'm not very tranny inclined
It just pops out like the seal on your harmonic balancer. It is in behind the torque convertor.
BTW, make sure that your torque convertor goes in all the way when you put it back in.
Ontario Rodders |
tranny
ok thanks for the advice i'll defiantly do so
| 4t80e Cadillac Transmission Problems? | mile-hightoyz | Transmission - Rearend | 8 | 05-12-2008 09:15 PM |
| Internal Reaction (Ring) Gear shattered in 700R4... | indy_85stariones | Transmission - Rearend | 8 | 11-30-2006 05:31 PM |
| 4L60E transmission problems | BICHN69 | Engine | 1 | 08-14-2004 11:23 PM |
| Engine Problems, Oil related or coincidence only? | Francis | Engine | 1 | 05-12-2004 06:56 AM |
| Help!! Ford Windstar Transmission Problems | NAIRB | Transmission - Rearend | 0 | 05-11-2004 08:25 PM |
