transmission problems
my 95 z71 4speed automatic was rebuilt about 1 year ago.never had any problems until the other day.went to work all's well.leave and i've lost overdrive.2miles later lose third.then second.all i have now is first and reverse.if i drive down the road it stays in first till i let off gas then nothing please help thanks
I would scan the vehicle with a proper scanner. Read the data stream to see if the PCM is telling the trans to shift. Check for other items out of parameters
Does the speed-O function correctly?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
speedometer is working.will have to get it to a shop for scan after holiday thanks
if its a 95 you can scan it for problems,it should show electril faults and major mechanical faults.try just checking the fluid,first and reverse are under the least stress and are usually the last to give under major slippage problems.
it sounds like ur having a problem with line pressure,because ive been working transmissions for over six years and thats not a common problem what youve described. does the trans make a whining sound,if it does that would mean the filter is clogged and it isnt getting fluid to the trans.when first works does it slip at all? |
transmission is whining a little will have to check out filter first.then will go get scan.1 st gear is real strong no slippage at all reverse comes and goes.thank for the help guys
| Taurus transmission glitches... | awbazar | Transmission - Rearend | 9 | 05-21-2009 04:34 AM |
| 4L60E transmission problems | FlyiongTiger | Transmission - Rearend | 3 | 01-26-2009 07:03 PM |
| 4t80e Cadillac Transmission Problems? | mile-hightoyz | Transmission - Rearend | 8 | 05-12-2008 09:15 PM |
| 4L60E transmission problems | BICHN69 | Engine | 1 | 08-14-2004 11:23 PM |
| Help!! Ford Windstar Transmission Problems | NAIRB | Transmission - Rearend | 0 | 05-11-2004 08:25 PM |
