Transmission Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2004, 12:03 AM
I have a 1979 4x4 truck with a 350 engine along with a used turbo 350 tranny that i just put in. Right now I am on the brink of frustration with all sorts of weird problems that i cannot seem to resolve. The problems consist of very slow, sluggish speeds to very bad clunking when shifting from park to reverse or to neutral or to drive. I just put a brand new modulator valve in the tranny, and made sure that there was no leaks coming from it or the vaccuum lines. The result is still the same. I adjusted the idle on the carburator as low as it will go and that causes the shift from park to reverse to have a 4 second pause then clunk as it engages. I changed the fluid as well, and found out that the fluid was not burnt or chared, but just as clean as if I had just put it in with some sludge on the bottom of the pan. Can anyone please give me some advise on how I can correct this problem.
-Steve
Old 02-10-2004, 04:49 AM
STUPID is as STUPID does...
That's the frustration of buying used junk... Especially transmissions... The fluid may be clean but, the previous owner probably went through the same process you are, hoping to magically "fix" a worn out trans... Now you have to pay again and do the work all over....
I'm not trying to flame you here bud. I just want you to realize you haven't saved yourself any time, money or hassle by buying a used trans. Step up the first time, get a warrantied rebuild, which probably isn't much more then the used hunk of junk you bought, and do it right the first time... Just a voice of experience.
Mark
Old 02-17-2004, 02:36 PM
Thanks Mark. I appreciate your input. I went looking arond for a warrentytransmission and found one for $630 plus a $100 dollar core charge with a 15 month/15,000 warrenty.
Steve
Old 02-17-2004, 03:34 PM
630 bucks huh? Around here a rebuilt th350, with a shift kit, is 300 even... No core either... I guess that's the price you pay for that "big city" livin...
Mark
Old 02-17-2004, 04:26 PM
Shop around a little more. Or if you have a garage and some space, do the rebuild yourself.
Get a rebuild video from Technical Videos web site for ~$30, buy a $12 Haynes book on rebuilding TH350s, shop around for some tools to compress the springs etc. Total amount of money spent + experience = priceless. And moneywise it will be still less than $630 (at 19 yrs old that is a lot of money).
Oh and do some searches on this site for rebuild information: clearances, shift kit optimizations etc. A lot of people have done it. You can do it too.
Good luck,
Denis
'67 Camaro RS
