transmission problems. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2006, 04:59 PM
i have a 98 zr2 i have no reverse and it shifts hard out of first i have an obd 2 auto scanner and it pulls no codes and passes it when you put it in reverse it starts to whine tranny s full any one have any suggestions
Old 07-14-2006, 09:59 PM
FOHLDMON's Avatar
0-100 in 2.7 seconds
trans problems
if i rember right you have a 4t60e not a 4t80e,eather way you should pull the pan and check for metal in the pan.if there is the wine you here is most likely a planet gear or thrust bearing wich has started comming apart.the no reverse is possibly burt up reverse cluth pack or sprag,and it shifting hard ( if theres metal in the pan)could of hung up valve in the valve body.there could be several things that can cause what you have described but more than any thing check the pan and magnet for metal in the pan and burnt fluid.if there is more than a good coating on the magent the trans may need internal work done to it.hope this helps tommy
4t80e Cadillac Transmission Problems? mile-hightoyz Transmission - Rearend 8 05-12-2008 10:15 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
4L60E transmission problems BICHN69 Engine 1 08-15-2004 12:23 AM
Engine Problems, Oil related or coincidence only? Francis Engine 1 05-12-2004 07:56 AM
Help!! Ford Windstar Transmission Problems NAIRB Transmission - Rearend 0 05-11-2004 09:25 PM
