Transmission question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2006, 04:37 PM
I'm presently running a power glide trans behind a 400 small block. I'm not sure what the rear end is but it's turning around 2800 rpm at 55mph. I'm thinking of going to a b&m th-350 with the 2400 hole shot converter. Any suggestions or info on this setup?
Old 10-29-2006, 06:56 PM
The Powerglide and the Turbo 350 both have a 1 to 1 final drive so your RPMS in high gear will remain the same ...
The Powerglide is a 1.76 low gear and the Turbo 350 is 2.52 so the car should leave a good bit bit quicker ... and be more enjoyable on the street ...
Deuce ...
Old 10-29-2006, 07:57 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
perhaps a 1.82 low first gear powerglide tranny is in there.......... little difference though.
we would need more information on the car & engine & rear gear & tire size & etc ...... to make a judgment call on the 2400 stall converter you mention
Old 10-30-2006, 06:02 PM
The rear is a 9" Ford posi. I don't know the ratio but the drive shaft turns 3 times for every one of the wheel. The tires are 15" 60's. Thanks for your response
1994 Grand Am Transmission fluid question StevenC Transmission - Rearend 0 07-18-2005 10:23 PM
FWD Cadillac Engine RWD Transmission Question Dusty82 Engine 4 03-19-2005 03:39 PM
Transmission swap question shatteredmindofc Transmission - Rearend 1 03-10-2005 02:04 PM
Transmission rebuild question? TonyMac Transmission - Rearend 2 06-08-2004 06:53 PM
Question about astro van transmission??? Robbie Transmission - Rearend 2 05-27-2004 01:50 PM
