Transmission Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2007, 03:12 PM
mikedag's Avatar
So i am puttong an 88 350 in my nova its a truck engine completely rebuilt to 3.25 hp and is a very strong engine. it is coming with the trany but it is a 4 speed and my car is a 3 speed. is it going to need new mounting brakets or will it fit in the old ones and also how do i change my dash cluster to a 4 speed when it is a speed dash cluster... if u can help please do.
Thank You Mike
Old 02-08-2007, 03:24 PM
McLeay F1's Avatar
Last journal entry: body work
if its a 4 speed auto you have to modify cross member shorten drive shaft and you will need a carb bracket for throttle valve cable off the trans
Old 02-08-2007, 03:27 PM
MI2600's Avatar
Member# 3287
Standard or Automatic? 3-speed what? 4-speed what? Some are bolt-ins. Some require mods.
Old 02-08-2007, 03:54 PM
johnsongrass1's Avatar
Race it, Don't rice it!
3.25 Hp ain't much yo.
Old 02-08-2007, 04:28 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You need to be more specific....what trans do you have now and what trans are you talking about puting in?
Old 02-08-2007, 11:16 PM
Might check with Shiftworks and see if one of their shift indicator lenses can be modified to fit your Nova.
http://shiftworks.com/lens.htm
1994 Grand Am Transmission fluid question StevenC Transmission - Rearend 0 07-18-2005 10:23 PM
FWD Cadillac Engine RWD Transmission Question Dusty82 Engine 4 03-19-2005 03:39 PM
Transmission swap question shatteredmindofc Transmission - Rearend 1 03-10-2005 02:04 PM
Transmission rebuild question? TonyMac Transmission - Rearend 2 06-08-2004 06:53 PM
Question about astro van transmission??? Robbie Transmission - Rearend 2 05-27-2004 01:50 PM
