transmission question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-19-2006, 01:43 PM
Choctaw Bob's Avatar
Originally Posted by diabolical
wheel bearings were done a couple of years ago (doesn't every corvette need that?) but, i did check...wheels are tight...no play.
as i stated before, tires were balanced on a hunter gs9700..supposedly top of the line.... at a ford dealer.
when i was removing the half shafts, some of the u-joint straps were kinda loose..i could remove them with my fingers...sheesh. and, i found one u-joint that was tight in the trunion. it was hard to move back and forth. so, i replaced that one and it swivels smoothly now.
so...this is what i'm figuring: (lol) since a couple straps were loose while the wheels were hanging,(this puts pressure on the u-joint). when the wheel has weight on it, the straps maybe gave enough for the u-joint to be loose. keep in mind that the half-shaft is also part of the wheel travel assembly, so, when the car is jacked up, the rear wheels kick in at a gross angle. this puts pressure on the u-joints, so it might appear that they are tight, but once on the ground, they might be loose.
f$@$#@# corvettes!!!!
anyways, when i feel ambitious, i'll put it back together later and see what happens. if the vibration is still there, i'll burn the car. lol
hey...i appreciate the help....this has been a big downer for a long time.
Patience and persistance is necessary in owing a Corvette. You will get it in the end.
On the tires, even if they were balanced, balance weights fall off. I have had them fall off on the way home from the tire shop. You can't assume anything, especially you can't assume that people will do their jobs correctly. When I have a problem like this, I check and recheck everything until I find it.
  #17 (permalink)
Old 04-19-2006, 02:48 PM
bob, i'm not 100% confident this will solve my problem because i didn't find anything extraordinary in the u-joints, unless the loose strap and one stiff u-joint are enough to cause my problem. i was hoping to find a broke bearing or something like that.
i'll assemble it tomorrow night and see if it does. if it doesn't, then i know the problem must lie somewhere back there. thanks again!!
i'll post back when assembled and i try it out.
  #18 (permalink)
Old 04-19-2006, 02:58 PM
The stiff u-joint can certainly cause the problem. Good luck!
  #19 (permalink)
Old 04-19-2006, 06:30 PM
Have you tried swapping the tires front to back?
  #20 (permalink)
Old 04-19-2006, 07:07 PM
yep...tried every which way i could think of. i then went out and bought new tires...and had them balanced with the hunter system. i was hoping for a smooth ride.....no change.
maybe i will get lucky and doing these u-joints might be the ticket.
  #21 (permalink)
Old 04-19-2006, 07:44 PM
tnsmith10's Avatar
when will it rain???
didnt u say that uve already done that twice??? i personally think ur throwing ur money away...
  #22 (permalink)
Old 04-19-2006, 07:50 PM
Sometimes gremlins like this can drive you crazy for a while.
  #23 (permalink)
Old 04-19-2006, 09:48 PM
the first set of tires were kinda old anyways, but i had them tested on the balancer. two were good...one was borderline and one was bad. i returned them where i bought them and they gave me 4 new ones...free except for that taxes. i then took the 4 new ones up and had them balanced.
1994 Grand Am Transmission fluid question StevenC Transmission - Rearend 0 07-18-2005 11:23 PM
FWD Cadillac Engine RWD Transmission Question Dusty82 Engine 4 03-19-2005 04:39 PM
Transmission swap question shatteredmindofc Transmission - Rearend 1 03-10-2005 03:04 PM
Transmission rebuild question? TonyMac Transmission - Rearend 2 06-08-2004 07:53 PM
Question about astro van transmission??? Robbie Transmission - Rearend 2 05-27-2004 02:50 PM
