transmission questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2010, 07:24 AM
Eric63M's Avatar
Last journal entry: Getting all the parts together for my LTX build
1 shallow puddle later i'm replacing the transmission in my durango. it has the 46re with lockup convertor.
Yesterday i got the new trans in and had a few questions. do i need to pour some fluid in the convertor before i install it? also has anyone every tried the valve body reprogram kit for a 46re? what type of results should this bring? thanks Eric
Old 06-05-2010, 08:47 AM
delawarebill's Avatar
oil in coverter...
yes u do.. about 1 or 2 qts will be fine.. the converter takes alot of oil.. make sure u have some more on hand to fill the tranny.
Old 06-05-2010, 09:54 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the trans converter does not require filling prior to installation.. the trans pump fills the converter as the engine runs.
Check the proper procedure for filling - checking this trans.. In neutral with parking brake on. I suggest a person inside the vehicle to hold the brakes on too.
the TransGo kits for the 46re trans work well. I would keep the settings on the mild side for street use
Old 06-05-2010, 10:44 PM
i advise prefilling it save alot of time and helps get the trans off to a good start
Old 06-06-2010, 10:45 PM
Eric63M's Avatar
well got the transmission in today, yay.except the y pipe wasnt welded right so now i have to spread it about a inch.
_nly one more question. how should i break this transmission in? baby it for 1k miles or just reverse it out of the driveway, drive to the stop sign and if it hasnt failed it isnt going to then just open it up? whats everyones opinon here?w
Old 06-07-2010, 12:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
My take on this is any rebuild where new parts are involved need a certain amount of time to wear in together before putting the hammer down in earnest.
That said, 1K might be a bit excessive but wouldn't hurt. A couple hundred would suffice, IMHO.
Old 06-08-2010, 07:35 AM
Eric63M's Avatar
thanks for the aadvice, I've already put 64 miles on it ( usually drive the mazda for the mileage). shifts are great at partial throtle, the new stall is going to take a bit to get used to (2200rpm), other then that everything is great and I'm extremly satisfied. I didn't rebuild the transmission myself though, bought it through a company called santan transmissions out of queen creek arizona, very good company as far as my experience with them. once again, thanks for the help everyone.
2 Questions: Transmission? 39chevy Transmission - Rearend 2 08-16-2009 01:24 PM
Doug Nash 2spd auxliary transmission questions slide Transmission - Rearend 3 07-20-2009 03:08 PM
I'm the new guy with a lotta questions. Can you answer all of 'em? LittlePwny Engine 17 04-10-2009 02:08 AM
More transmission troubles chrisflock Transmission - Rearend 3 08-10-2007 11:07 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
