Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission/Rearend
Old 03-18-2002, 10:28 AM
wellcontrol wellcontrol is offline
It all depends on what you have.If you started
with a 350/automatic trans setup I would keep the
automatic,maybe install a shift kit(depending on
if you are pulling or racing),and change the rear
gear ratio to 3.73(if available).This should give
you enough pulling power and help to get you off
the line quick enough.
If you started with anything smaller(a 305 or
**gasp** a 4.3 V6)then you will need a stronger
trans and possibly rear end(doubt it on the rear
end though,probably just the gear change.)
If you need any more help just e-mail me at
