Transmission/Rearend Combo Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2011, 01:17 PM
Hey guys,
I have a 67 Camaro with a small journal 327 and need some advice on rearend gears ratios. I rebuilt my engine with a voodoo 262 cam, and have a freshly rebuilt m22 going behind it. The problem (maybe) is that my rearend has the stock 3.08 gears. Is it going to be a dog? I won't be racing it, and will mostly only drive it around town, with maybe a trip up to my family's cabin in the mountains once and a while. Should I change to a lower gear like a 3.55 or 3.73, or should I just leave it alone. I want the car to have some balls when it needs it. You don't build a muscle car and aim for low performance you know?
Any info would be great!
Chris
Old 06-22-2011, 04:36 PM
prostreet6t9's Avatar
Differential/Driveline
With a 26" tall tire 3:55. 28" tire 373's.
Old 06-23-2011, 09:17 AM
cranky1's Avatar
Just stuck
In the 70's, I had a 66 Mustang Fastback with 289, headers, Torker intake, 600 Holley, T-10 and 2.80 gears with 26" tires and it ran a 15 flat in the 1/4 and got 21 running 70 but with a nearly stock cam. In town it wasn't hard on the clutch since the car was only 3050 and I liked being able to cruise faster than 70 and did that a lot. A 3.50 gear would have been nicer for the light to light stomps but didn't do that a whole lot anyways. How does your car act with the 3.08? If you don't have it running yet, give it a shot and see how it does. In the 1/4, you might like how it chases down the competition on the top end...
Old 06-23-2011, 05:53 PM
Cranky,
Good point. I don't have it running yet, but should in the next few weeks. The rearend is in good shape, doesn't leak and no issues with the gears. I, too, will not be dragging it from light to light. My engine is boared 60 over, flat head pistons, 194 camel hump heads (ported and polished), performer intake, voodoo 262 cam, and a performer carb...which is all the power I'm looking for. Perhaps I'll put it together, drive it, and change the gears if it's not a good fit. Are they pretty straight forward to swap out?
Thanks,
Chris
Transmission and rearend combo Skinnz Transmission - Rearend 10 02-21-2010 03:53 AM
Best transmission/rearend combo? mrdreex Transmission - Rearend 10 03-12-2008 09:36 PM
Engine-Trans-Rearend combo DrBee8457 Hotrodding Basics 7 04-19-2007 01:49 PM
tranny and rearend combo? dj72chevy Transmission - Rearend 4 07-01-2005 07:52 AM
rearend/tranny combo Lowgmc83 Transmission - Rearend 1 11-28-2003 01:38 AM
