Transmission rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2007, 10:54 AM
I was wondering what specialty tools will be needed to do a transmission rebuild. thanks, ahouse
Old 06-17-2007, 11:48 AM
jakeshoe's Avatar
I am wondering what type of transmission you would be trying to rebuild.
Old 06-17-2007, 12:10 PM
700r4, we also are putting a b&m shift kit in it
Old 06-17-2007, 12:36 PM
jakeshoe's Avatar
You will need a low/reverse clutch spring compressor tool.
You will need an input shaft teflon seal installer and sizer.
You will also need a way to replace various bushings.
You will need a method to compress the various clutch return springs in the drums.
I wouldn't use the B&M kit, buy a TransGo Reprogramming kit.
Old 06-17-2007, 01:05 PM
JeffB's Avatar
700R4 build
#1 Go to( www.transmissioncenter.net) they have everything for 700R4's,ORDER the DVD on 700R4's and go from there.
More transmission troubles chrisflock Transmission - Rearend 3 08-10-2007 11:07 PM
Transmission fluid problems? Croz Transmission - Rearend 7 12-22-2006 01:37 AM
Hughes vs. TCI automatic transmission vs. local rebuild surfshark Transmission - Rearend 9 11-01-2006 09:11 PM
4L60 rebuild possable? fumplet Transmission - Rearend 11 09-13-2006 11:27 AM
Backyard Transmission Rebuild Edahall Transmission - Rearend 3 03-07-2004 05:22 PM
