Transmission rebuild kits & sources - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2012, 12:47 PM
Gearhead forever's Avatar
I'm considering swapping my TH350 for a 4 speed manual in my full size gm truck, but that swap looks a bit daunting. I might just keep and rebuild the TH350 after all. (or find 700r4)
Does anyone know a good supply of full rebuild kits for these? I cant afford $1500 to have my local rebuilder do it
Old 09-17-2012, 06:38 PM
Cape Cod Bob's Avatar
I got a kit off ebay about $80 . I did not replace all the sleeve bearings . Just the ones that were easy. It wasn't that worn just been laying around and had water in it. I got a rebuild book $20 on amazon and with the help on this forum I made it thru and works great on my sedan.
Old 09-17-2012, 07:08 PM
look up there should be local shops for this i just did my trans in my f350 i used a Daaco triple disk with a 1200 stall all Borg Warner clutches bands new bushings everything just about except for the hard parts i also threw a shift kit and new solenoid pack, it cost about about $900 dollars from a local trans parts dealer and they where more than happy to sell me all the parts, and what drove my cost up was the converter and the solenoid pack if i used a cheaper converter and rebuilt solenoid pack i would of only have spent like $600
Old 09-18-2012, 08:36 AM
SSedan64's Avatar
Makco has very complete Kits.
Transmission Parts 700R4 GM Rear Wheel Drive
You may want to find somewhere in Canada to save on S/H tho'.
Old 09-19-2012, 04:28 PM
Thanks guys - on a scale of 1-10, how tough would you say it is to rebuild a TH350? I want to do it right with premium & hardened parts, shift kit etc.....
Old 09-19-2012, 06:42 PM
SSedan64's Avatar
The TH350 is much easier & cheaper to build than the TH700R4.
Good buildup Info here by "Jakeshoe" >> http://www.hotrodders.com/forum/th35...ch-145361.html
Rebuild Kits medic4.life General Rodding Tech 3 05-25-2009 03:09 PM
Rebuild Kits 400smb_s10 Engine 4 06-04-2007 03:26 PM
Transmission Swap Parts Sources. M&M CUSTOM Transmission - Rearend 11 02-20-2006 05:29 PM
10 rebuild kits lluciano77 Transmission - Rearend 1 08-04-2005 04:45 AM
B&M vs. TCI vs. Other Transmission Kits jvenice Transmission - Rearend 3 11-02-2002 11:48 AM
