transmission rebuild problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2011, 07:13 PM
my name is ron and i have been working on my mustang for two years and i am now working on the driveline.removed the 4cyl and installed a 302 i have a transmission out of what i was told was a 1993 aod .it is an aod but the problem i have is the 3-4 accumulator is missing an i dont have the tag to identify the trans.on the bellhousing there is a big #24 and the case #s are RF-E90P-7006-AA any help would appretiated thanks
Old 03-15-2011, 08:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Ford deleted that accumilator before the 1993 year model
Old 03-16-2011, 03:12 PM
JeffB's Avatar
In 1988 and later they improved the valve body and deleted it,for more info on AOD's check out this link: www.clickclickracing.com
Transmission shifting problems--Trans rebuild or Clutch?? willys93108 Transmission - Rearend 6 01-09-2011 01:04 PM
t5 transmission rebuild speede5 Transmission - Rearend 1 05-14-2010 10:43 AM
C4 transmission rebuild 49fordp/u Transmission - Rearend 6 07-05-2009 06:28 PM
Transmission Rebuild TH-400 novatech Transmission - Rearend 4 02-15-2005 07:47 PM
Rebuild M-22 Transmission beekster Transmission - Rearend 0 09-10-2002 05:46 AM
