Transmission/shifter matchup - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2005, 10:20 PM
Pcr21688's Avatar
Yes i have a 69 camaro with a TH350 transmission and it will not match up with my shifter so instead of it displaying the gear you are in you have to find the gear and the shifter doesnt match up with that gear. Can somebody give me a hint or tell me how to fix this? ...
Thanks,
PCR21688
Old 12-23-2005, 01:11 AM
TechnTool's Avatar
OldSchool MotorHead
There should be an oblong bolt hole somewhere in the linkage for adjusting the alignment of the shifter. I loosen the adjuster bolt, put the trans in Park by hand, then put the shifter in Park, then tighten the bolt. the rest of the gears should line up. If they don't, then alter the length of the shifter rod on the trans or the shifter to alter the length of throw so they match up.
Old 12-24-2005, 06:05 AM
Pcr21688's Avatar
it doesnt have a shifter rod it has a shift cable
clutch matchup questions for SBC to T- 56 hotrodf1 Transmission - Rearend 0 12-17-2003 09:49 PM
