Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - transmission slip questions?
Old 08-11-2007, 07:45 PM
gods_flame03 gods_flame03 is offline
yeah when i changed the fluid. there was a metalic resin in the bottom of the pan.. But ok. i suppose i should tell the whole story.. Before i changed the fluid it did not slip.. It would vibrate really hard sometimes.. And i figured out that it vibrated whenever i would go uphill.. its almost like its not shifting down into a lower gear and its bogging down and vibrating.. And it also happend when i was driving on the highway and it would start to vibrate and i just had to give it more gas to push through it.. SO... i changed the oil and the vibrating a stoped and it started slipping.. And it only happens after it has warmed up..
