Transmission slips on curves and turns only? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2003, 11:09 AM
Post Transmission slips on curves and turns only?
72 nova, 350, no positraction, just a peg on the rear axle.
I can feel it slip but only on turns and curves when accelerating.
could it be the differential or the tranny?
Old 03-14-2003, 12:07 PM
Post
Could it be the tire?
Old 03-14-2003, 12:12 PM
Post
i'm thinking it might have to do with peg in the axle popping in and out during turns but then again what do i know?
Old 03-14-2003, 09:38 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Just go straight like I do! What self respecting race car goes around corners anyway?
Old 03-15-2003, 12:20 AM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
Post
Sounds like an A/T loosing fluid like it's low
Old 03-15-2003, 03:56 AM
Post
What kind of transmission does it have?????????
If it's a th350 it could be excessive governor endplay.
I would assume you would check the fluid first thing so i left that out.
[ March 15, 2003: Message edited by: Jason ]</p>
Old 03-15-2003, 04:49 AM
390xw's Avatar
Post
hey man ive found that to normally be either not enough fluid or tourqeconverter is screwed
Old 03-15-2003, 04:50 AM
390xw's Avatar
Post
P.S actualy one of me commadores is doing it now and i know its the converter i spose i shouldnt give it such a hard time lmao yea right good luck
Old 03-15-2003, 06:18 AM
airworld2's Avatar
Post
check your speed if dash shows your moving faster in corner you have slip in rear end or tires , but if you hear higher rpm and no increase in speed your trans is slipping, I'll say your transmission is slipping fluid level would be first thought, might be loose filter only 2 small bolts to hold fiter on small gasket too, some time wrong dipstick to your fill tube will show incorrect fluid level( shows full, when it's low)
airworld2
Old 03-16-2003, 10:50 AM
adtkart@aol.com
Post
If it is actually the trans slipping, I would have to believe it is in the fluid level or pickup. The torque comverter would show up during hard acceleration from a stop going straight. Make sure of the correct fluid level. If the level is correct, it could be a loose filter or, I have seen filters installed without the gasket. Since the filter is made of either thin sheet metal or plastic, it is east to get a poor seal without a gasket. This would permit poor fluid pickup when the level drops only about 1/2 ".
Old 03-16-2003, 12:16 PM
Post
I like what willys36 said what self respecting racecars turn--
My tranny slips but i dont care--its a beater I actually like that it slips sometimes--it adds character but then again thats me I am a complete idiot
