Transmission stuck in 1st ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2009, 10:30 PM
1990 XJ6 Jaguar, Engine works well, Transmission is stuck in first. Inspecting the car in the morning for a friend, It is either the ZF4HP22 or the ZF4HP24 Transmission,
Is this a Vacuum modulator problem?
a Governor problem?
Linkage trouble?
Old 06-01-2009, 03:46 PM
68MercCougar's Avatar
tranny
i dont think a Vacuum modulator problem because its a 1990. its all electrical now... It could be linkage but if it goes into park you might end up having to drop it and see. Kinda hard to give advice with that description
1991 Chevrolet K2500 4X4 transmission problems Craig Eppley Transmission - Rearend 15 02-25-2008 05:02 PM
Race Transmission Slipping brainsboy Transmission - Rearend 8 03-05-2005 08:01 PM
turbo 350 transmission kickdown stuck 1957GMC100 Transmission - Rearend 0 12-21-2003 04:48 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
Transmission JMac19 Hotrodding Basics 3 10-01-2003 12:58 AM
