Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission swap in 1962 impala
  #16 (permalink)
Old 05-29-2011, 05:54 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by itsandre
Hey all, to answer the question about the tranny swap from a 3sp manual to the th350. Yes the drive shaft has to be shortend. About 5" and the yolk has to be replaced as well. The splines are different. Brought it to a driveshaft shop and the whole job cost about $230. Balanced the entire two pc shaft and new ujoint at the yolk.
it is a drive shaft "yoke"
