Transmission swap in 1962 impala - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-29-2011, 05:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by itsandre
Hey all, to answer the question about the tranny swap from a 3sp manual to the th350. Yes the drive shaft has to be shortend. About 5" and the yolk has to be replaced as well. The splines are different. Brought it to a driveshaft shop and the whole job cost about $230. Balanced the entire two pc shaft and new ujoint at the yolk.
it is a drive shaft "yoke"
  #17 (permalink)
Old 05-29-2011, 08:04 PM
Volcano
Last journal entry: Interior getting installed
62 impala tranny swap
Ok. To any who might be interested in a lil more info on the tranny swap (turbo 350) for an early 60's impala this might help. I needed to shorten the drive shaft in my 62 by about 5 inches. What I did was find a stock single piece shaft from a 70 chevelle that was almost a perfect fit. And it only cost me $45 bucks. I needed about 1/2 an inch off that so I found a yoke with a shorter base. Worked perfect. hope this will help the next guy.
1962 Impala Again Impala_Bill Introduce Yourself 3 08-06-2009 08:11 PM
1962 Impala SS cylinder W/AC lolli780 Introduce Yourself 3 11-12-2008 05:10 PM
1962 Impala SS ? kgard Hotrodding Basics 4 05-30-2008 09:21 AM
1962 Chevy Impala michael brugman Introduce Yourself 2 09-03-2006 08:30 PM
1962 impala 8.2 rearend pretorin Transmission - Rearend 2 11-23-2004 12:17 AM
