transmission swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2011, 11:12 AM
unearthly57's Avatar
coldpooinapapercup
Last journal entry: the beginning...
transmission swap
i got a 57 235 chevy stovebolt. i want to swap out the trans for a newer one. i read that a 80's late model s10 trans with an external clutch will bolt up to a 235 bell housing with minor adjustment. i can get my hands on a 85 chevy s10 4 speed standard trans with the external clutch. will it bolt up work? i do know there will be drilling involved and proper spacing knowing the input shaft is longer then the original.
Transmission swap rockmason Transmission - Rearend 3 12-05-2005 09:09 PM
transmission swap help cbonsall Transmission - Rearend 4 12-25-2004 11:41 AM
transmission swap deancharlie03 Transmission - Rearend 3 03-19-2003 04:02 PM
Transmission swap Chucks,57 Transmission - Rearend 0 02-20-2003 05:06 PM
AOD transmission swap Doug Renton Transmission - Rearend 1 10-07-2002 03:23 AM
