Transmission swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2005, 04:56 PM
Transmission swap
The transmission that I have in My 1984 chevy 4x4 pickup is improperly functioning. It is going to blow soon. I was wondering what it would take to get a rebuilt 700R4 tranny out of a 1980's special edition trans am to fit in place of my TH400. I have the 700R4 but I don't know if it would need to be modified much to fit. Any help would be appreciated.
Old 06-24-2005, 06:31 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
O'Flaherty,
Start here...
http://www.transmissioncenter.net/Tr...asurements.htm
First off, I am not a transmission expert by any means.
I believe you would want a 700R4 out of a 4x4.
Besides that...
The 400 is about 5 inches longer to the trans mount than the 700r4(according to the chart).
You would need to move your trans crossmember, and have a driveshaft of the correct length.(buy a longer one and have it shortened). I believe the trans yoke is also different, so that would also need to be replaced.(can be done at the same time as shortening and re-balancing)
You will also need to find the TV cable/manifold brackets for a 1984 chevy with the same carburetion as your vehicle.
That's about it.
Personally, I would try to find a 1985 or newer 4x4 700R4.
Old 06-24-2005, 09:02 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you will need a 4x4 700 tranny and the matching transfer case to swap into your truck.
the t-400 output shaft is larger than the 700 , so you need the matching parts & transfer case to swap out.
As mentioned:
You will need the 700r4 TV cable hook up items at the carb. Filler tube / dipstick , converter lock up kit
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
Transmission swap information jwhclayton Transmission - Rearend 5 06-23-2004 02:12 PM
Transmission Swap Steven_O' Transmission - Rearend 2 11-18-2003 09:56 PM
Transmission swap Chucks,57 Transmission - Rearend 0 02-20-2003 05:06 PM
