Transmission Swap 700r4 in place of 4L60E? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2012, 10:17 AM
I'm wanting to take my 92 GMC 700r4 transmission 4x4 and put in 93 Chevy Blazer what would I have to do to make it work in the Blazer because the 4l60e transmission is bad and is it possible to change it over to a 700r4 transmission?
Old 02-27-2012, 06:55 AM
78 Z28 Camaro
Last journal entry: 700r4 still running strong
I might be wrong but I thought 4l60e were not used until late 93. Yes it would work. But if it is an 4l60e your ecm wont be able to connect to the 700r4.
Old 02-27-2012, 05:25 PM
I apologize I all I know it is a 4l60 16 bolt pan and what would I have to do to make the passing gear work on the 700r4 because it's cable and the 4l60 is electril selenoid.
Old 02-27-2012, 07:19 PM
Crosley's Avatar
Wiki Edits: 1659
The vehicle with the 4L60e will set many trouble codes with the the 4L60e trans removed.
You will need to check the throttle arm for the needed connection for the TV cable of the 700r4 type trans.
Tranny swap 94 silverado 2wd 4L60E to a 700R4 nathanryan32181 Transmission - Rearend 3 12-28-2011 03:07 AM
4L60E swap to an 700R4 Brass Monkey Transmission - Rearend 3 06-16-2011 04:27 PM
will th350 bolt in place of 4l60e? 2manycruisers Transmission - Rearend 9 12-22-2010 08:44 AM
700r4 to 4L60E swap chevy_c10 Transmission - Rearend 19 05-10-2009 08:30 AM
t-400 in place of a 4L60E in a 4x4 ? the frog Transmission - Rearend 2 08-22-2007 07:15 PM
