Transmission Swap Parts Sources. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2006, 08:15 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I am swapping a manual transmission into my 1981 Malibu, and since these cars had a manual transmission as a base option they ("SHOULD") be relatively easy to come by somewhere.
I just haven't found out where yet though.
I need a source for a new clutch fork, GM part number 14007356. I can't find it anywhere.
I could get away with a good used one IF I could find one.
I also need a new or non rusted original dust shield, but have found a couple of them on Ebay. It has the squared off corner around the starter, not rounded like most.
I am also swapping a 4 speed into my Suburban, but I don't know if I want to go the extra steps and make that thing a 4X4 or leave it rear only, I have all the parts for it on shelves for either way.
Drop me a PM if anyone knows where I can find those things online.
Old 02-16-2006, 08:47 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
www.car-part.com If it was an original factory piece one of those guys may have it somewhere..
OMT
Old 02-17-2006, 02:59 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
There wasn't anything much in their drop down menu, and no place to enter search terms for clutch fork.
One thing I tried to look for led me to another selector at a different place and didn't have that part listed in that menu.
Thanks anyway.
This should be a semi find-able part, since 80 and up A/G body cars with manual transmissions had this particular slutch fork. The 78 and 79's list a different (and VERY available) fork for those years, it just won't work with my particular bellhousing.
This is the fork I need.
And the dust shield I need, (the bottom one), I have a lead on this right now though.
Old 02-17-2006, 11:28 AM
RippinRon's Avatar
iraqi taxis
Back in the late 70's early 80's GM made a bunch of malibus with 3.8s with 3 or 4 speeds that were destined to the middle east as taxis. They never got there and the majority ended up in Canada and can be found here and there. If your interested I have a clutch pedal for sale that is designed to use a 82-92 f-body hydaulic clutch master cylinder. You could get a hydraulic throwout bearing or a stock slave cylinder to acctuate your clutch. It was designed by this guy that who built this http://www.montecarloss.com/ls1montecarloss/. I had bought it to swap into a 86 cutlass but sold it.
Old 02-17-2006, 07:47 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I haven't seen much luck with hydraulic throwout bearings, except for the local dirt track racers, they use them a lot around here.
I have some leads on stock parts, and have a couple cheats for using different parts swapped in that look like the right part, like a secend brake pedal heated and bent with a portion of the pad plate removed to fit the smaller pad for a clutch pedal, it looked pretty convincing when I seen the before- during- and after pictures of his swap.
Old 02-17-2006, 08:08 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I just got to looking the picture of the "correct" clutch fork, and got curious.
I bitmapped the picture and stretched a straight line from end to end taking into account the person who took the picture wasn't looking at it exactly from 90 degrees from either X or Y axis.
A straight line from center of the fork fingers and the the pivot ball lines up with the actuating end where the rod end fit's into.
What is in the way under the car to require the fork to be curved? Nothing from what I went out and looked to see.
I'll go out tomorrow and see what a more common part number fork that I already have looks like in this bellhousing, Now if I only knew what the measurement was between the two pivot points, and the the inner pivot to fork fingers, I could look for a different fork that would work.
I already know why this bellhousing has a lowered clutch fork opening, because of the close proximity of the floor pan.
The starter and exhaust go back on the opposite side of the car.
From what a bunch of websites are addressing for the oil pressure sending unit, I don't have one above the oil filter boss to have to worry about, and have been planning on adapting the sending unit to the fitting next to the distributor anyway.
Old 02-17-2006, 08:10 PM
Retiredrich's Avatar
My 78 Malibu has the easy to find fork as does the 79's like you said. I would consider changing the bell housing and using the 78 79 type fork. I think NPD sells an entire clutch linkage set up if my memory is correct. I think it's around $400.00 but not sure. Rich http://www.npdlink.com/modules.php?n...evelle_Catalog
Old 02-17-2006, 08:26 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I'll have to look into this too, I get a bunch of the NPD catalogs from them being a major sponsor of our Northern Chevelle Gathering car show in July.
I also seen that OPG, has a lot of the needed parts "except" for the fork.
In looking through the NPD catalog they show a picture or the very fork I need and have pictured above, BUT- they list it as for 1978-1981, which we have already determined there should be two different part numbers for this year range.
An online source I found lists the fork I need as a part number, but when put into their shopping cart, part of the end of the part number is removed, so I can't be surethat is the right one either.
It would be nice to know the measurements of the center points of the pivots, and and fork fingers to the first pivot point. I could than take this information to the local parts stores and hunt through their inventories.
Old 02-18-2006, 07:13 AM
RippinRon's Avatar
Heres a link to a good g-body site. I bought the his 1958 ford 9" rearend for my cutlass.
http://malibunorth.freeservers.com/TechPage.htm
Old 02-18-2006, 12:35 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I've seen his site before, lot's of good information there, but unfortunately not a source of my needed parts.
I'm going to look around the 'net and see if I can find a front side pic of this banana shaped clutch fork instsalled and see if there is a noticable need for the bend.
I might try and bend a used one myself and see what it looks like, if I have a used one laying around that isn't marked for future use.
I found a couple decent pics of the fork installed.
ID:	10124   Click image for larger version
ID:	10125   Click image for larger version
Old 02-20-2006, 03:12 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
With the 462606 bellhousing and it's lowered fork pivot ball, there is no way that the more common clutch fork #14066235 will come close to working.
The required shaping of the other fork would take just as much time and effort as completely fabricating one from scratch.
I spent almost an hour making a diagram of measurements and notes to go with them.
I gave up on changing an already stamped piece that will not work.
I might just try and fabricate my own, but still look for an original in good condition.
Old 02-20-2006, 06:29 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
I found a possible online source for the fork, but instead of buying it and getting the wrong one, I sent a link to the picture of the fork in my previous post for them to verify and get back to me. I told them I would buy it ASAP if it IS the same one. So now I'm down to aquiring the dust shield and all the linkage up to the pedal and neutral safety switch.
Parts stores woes lozinit Hotrodders' Lounge 23 02-17-2006 05:58 PM
Transmission rebuild parts list. 4 Jaw Chuck Transmission - Rearend 2 06-29-2004 09:04 AM
Transmission Swap Rex Tribble Transmission - Rearend 1 12-29-2003 08:22 PM
Parts sources? Catalogs? 52 Dodge Panel Hotrodders' Lounge 2 05-21-2002 09:20 PM
