Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - transmission swaping
Old 06-26-2012, 01:43 PM
rick 427's Avatar
rick 427 rick 427 is offline
Last journal entry: 33 WILLYS
You would have to take the trans apart and convert it to a 2wd trans by changing the output shaft,adding a speedo gear to the output shaft, and putting an extension housing on it....then it would be good to go.
