Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission temp gauge sending unit
Old 10-22-2012, 02:23 PM
Rocketbird Rocketbird is offline
Originally Posted by Irelands child View Post
This is where mine is located and as far as I'm concerned, close enough for anything I'm doing with my car (trans. temp. runs within a couple degrees of the engine coolant temp (175-180 on a 90 degree day):
That bung that you installed to your pan for the sending unit, is it just sealed by compression with rubber gaskets?
