Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission temp gauge sending unit
Old 10-22-2012, 04:46 PM
Irelands child's Avatar
Irelands child Irelands child is offline
Originally Posted by Rocketbird View Post
That bung that you installed to your pan for the sending unit, is it just sealed by compression with rubber gaskets?
It just takes a seal on the outside - you still need to have a ground - l drilled and tapped the cast pan. Got the sending unit from Egauges.
Irelands child
