-   -   Transmission temp gauge sending unit (http://www.hotrodders.com/forum/transmission-temp-gauge-sending-unit-225271.html)
Rocketbird 10-22-2012 10:42 AM
Hello everyone!
I would like to know where the best location to install a temperature sending unit for the transmission is and why?
If it matters the transmission I would be installing it into is a th400
sedanbob 10-22-2012 12:28 PM
Most aftermarket trans temp gauges I have seen put the sending unit on a tee fitting plumbed into the trans oil cooler line. This link shows the kit from B&M: B&M Automotive B&M Trans Temp Gauge Kit - Transmission Temp Gauge - Gauges & Mounting Kits - Interior Parts & Accessories - by 4 Wheel Parts
Irelands child 10-22-2012 01:12 PM
This is where mine is located and as far as I'm concerned, close enough for anything I'm doing with my car (trans. temp. runs within a couple degrees of the engine coolant temp (175-180 on a 90 degree day):
http://i70.photobucket.com/albums/i8...d/DSCN1921.jpg
Rocketbird 10-22-2012 02:23 PM
That bung that you installed to your pan for the sending unit, is it just sealed by compression with rubber gaskets?
Irelands child 10-22-2012 03:46 PM
It just takes a seal on the outside - you still need to have a ground - l drilled and tapped the cast pan. Got the sending unit from Egauges.
rbutler 10-24-2012 03:41 PM
Nice clean install. Looks much cleaner and stout than trans line method.
Rocketbird 10-24-2012 05:09 PM
So the bung is not welded? where did you purchase it from?
Irelands child 10-24-2012 06:50 PM
Got the sending unit from Egauges.com
Rocketbird 10-24-2012 07:30 PM
Ok I will search for one there. Not the sending unit itself but the bung that goes into the pan and see what I can find.
