Transmission temp gauge sending unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2012, 10:42 AM
Hello everyone!
I would like to know where the best location to install a temperature sending unit for the transmission is and why?
If it matters the transmission I would be installing it into is a th400
Old 10-22-2012, 12:28 PM
sedanbob's Avatar
Most aftermarket trans temp gauges I have seen put the sending unit on a tee fitting plumbed into the trans oil cooler line. This link shows the kit from B&M: B&M Automotive B&M Trans Temp Gauge Kit - Transmission Temp Gauge - Gauges & Mounting Kits - Interior Parts & Accessories - by 4 Wheel Parts
Old 10-22-2012, 01:12 PM
Irelands child's Avatar
This is where mine is located and as far as I'm concerned, close enough for anything I'm doing with my car (trans. temp. runs within a couple degrees of the engine coolant temp (175-180 on a 90 degree day):
Old 10-22-2012, 02:23 PM
That bung that you installed to your pan for the sending unit, is it just sealed by compression with rubber gaskets?
Old 10-22-2012, 03:46 PM
It just takes a seal on the outside - you still need to have a ground - l drilled and tapped the cast pan. Got the sending unit from Egauges.
Old 10-24-2012, 03:41 PM
Nice clean install. Looks much cleaner and stout than trans line method.
Old 10-24-2012, 05:09 PM
So the bung is not welded? where did you purchase it from?
Old 10-24-2012, 06:50 PM
Got the sending unit from Egauges.com
Old 10-24-2012, 07:30 PM
Ok I will search for one there. Not the sending unit itself but the bung that goes into the pan and see what I can find.
Temp Gauge Sending Unit and Aluminum Heads Pre-Tuner Engine 24 03-12-2012 07:24 PM
Tranny temp gauge sending unit location yragat Transmission - Rearend 12 12-28-2008 04:12 PM
Temp sending unit Bart Engine 3 06-23-2008 01:28 PM
Temp. gauge sending unit parameters? Thinking Man Electrical 0 11-20-2007 06:12 PM
Temp. sending unit dodge36 Electrical 10 01-14-2003 10:52 PM
