Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Transfer case question
Old 12-01-2012, 10:43 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Your lockouts are on the front axle and you have to get out of the truck and go to each axle end to manually lock the hubs..Get under the truck disconnect the shifter and see if you can move the shift lever on the transfer case to low hi and neutral...
Sam
