Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Transmission Transfer case question
Old 12-01-2012, 01:03 PM
feldpausch354 feldpausch354 is offline
Thanks for the info. I know it's a 203 transfer case because it doesn't have the 3 bolt cover on the back where the fill bolt is. And the truck has a 3 inch body lift so ill have to check that too. Also the cab is a 2 wheel drive cab but I don't think that makes a difference except you have to cut a hole in the floorpan rather than having an access cover.
