Originally Posted by feldpausch354
Thanks for the info. I know it's a 203 transfer case because it doesn't have the 3 bolt cover on the back where the fill bolt is. And the truck has a 3 inch body lift so ill have to check that too. Also the cab is a 2 wheel drive cab but I don't think that makes a difference except you have to cut a hole in the floorpan rather than having an access cover.
Check to make sure the shifter is not hitting the floor board when your trying to go all the way forward or back.
Most of the time I will have to make the shifter hole a little larger so the shifter will get all of the gears.
