Transmission troubles
I own a 1972 Nova with a 350 engine and i presume a turbo 350 transmission. The problem is I can get up to about 50 then thats when it starts to rev up real bad then slows down. I think its a gear problem or a power shortage or somethin. Any help would be appreciated.
Don't forget the obvious. Check the fluid carefully. The level might be hard to see.
Hey dude, check your ENGINE'S oil too. The SAME EXACT thing happened to me in my '65 stang. It feels like the engine is pulling the car towards the front (which it isn't actually doing, but it feels like the car is being pulled forward by some unseen force). Change your oil for me and let me know how everthing goes after that. =) Also, make sure that all of your vacuum is secured everywhere, 'cause a vacuum leak can mean bad things for shifting. Oil change and tranny oil change first off, and there's some sealant conditioner that you can get at parts stores for your transmission seals, and it will help everything run a little smoother. Man I hate Chevys.
Might also be a plugged transmission filter. I bought a truck (cheap) that would go about a block, then stop pulling. Turn it off for a few seconds, then start it up & drive another block. It had 1/4" of "jello" blocking the filter.
| 94 Dodge Transmission Electronics problem? | Native Gearhead | Transmission - Rearend | 7 | 10-17-2006 10:00 PM |
| Hotrodders Knowledge Base: Transmission - Rearend | Jon | Transmission - Rearend | 0 | 11-26-2005 06:23 PM |
| transmission oil type. | TVR383 | Transmission - Rearend | 3 | 06-05-2005 09:28 AM |
| Transmission Information. | M&M CUSTOM | Transmission - Rearend | 1 | 08-24-2004 03:15 PM |
| 83 Z28 Transmission - YIKES! | crandaz28 | Transmission - Rearend | 4 | 11-25-2003 07:43 AM |
