Transmission vent leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2011, 04:47 PM
I need some help people.
1994 BMW 540i transmission vent is leaking fluid.
It has no codes, shifts fine but it is leaking fluid from the vent tube.
I took it apart and could find nothing wrong except the "O" rings on the electrical connector. Put it back together and back in the car and it is doing the same thing. Any help would be GREAT.
Scholman
Retired
Old 01-15-2011, 02:46 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Is the trans cooler working properly anything wrong around it "restrictions" ?
Cole
Old 01-15-2011, 09:26 PM
dklong's Avatar
trans is'nt over filled ? is the trans cooler hooked up, is the proper trans fluid being used
Old 01-16-2011, 06:22 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Any moisture that is in the trans (possibly from pressure washing or even condensation or contaminated refill) can cause the fluid to escape through the vent.
8.2 10 bolt rear end leaking, where is the vent?! artillerystevens Transmission - Rearend 8 09-15-2010 06:44 PM
T-400 Fresh Rebuild; Vent Tube Leaking Konitz Transmission - Rearend 0 03-29-2010 07:10 AM
Th 350 Leaking from tailshaft vent??? Vegaguy Transmission - Rearend 6 06-15-2008 11:14 PM
Turbo 400 Leaking from vent mauserbull Transmission - Rearend 4 03-18-2006 07:40 PM
leaking cowl vent ping001 Body - Exterior 2 04-10-2002 11:52 AM
