Transmission vibration - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-07-2011, 08:43 AM
Bobs36ford's Avatar
Last journal entry: Video of new upholstery
u joint angle
attached is picture of u joint angle
  #17 (permalink)
Old 10-07-2011, 08:49 AM
Frisco's Avatar
Glad To Be Here
Originally Posted by cobalt327
Maybe I'm missing something (wouldn't be the first time...), but I don't see tire diameter effecting the driveline angle.
Think passenger car with the pinion shaft up 3 degrees and 26" diameter rear tires.
Compare that to an off-road vehicle, rock crawler or monster truck with the pinion shaft at the same 3 degree angle BUT with very tall (large diameter) tires installed. This will change the height of the rear u-joint from the ground and depending on how high in relation to the frame the engine is mounted, will change the driveshaft angle.
The crankshaft centerline angle to the ground and the pinion shaft angle to the ground should be the same as each other (or close). The driveshaft angle (which will effect the u-joint angles) is determined by how high or low the crank centerline is in relation to the pinion shaft and the length of the driveshaft will also effect the driveshaft angle. The shorter the driveshaft the greater the driveshaft angle.
  #18 (permalink)
Old 10-07-2011, 08:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sorry, maybe it's me but I just don't see it. I often need to think in extremes to get my head around a concept. If I think about a vehicle standing on it's nose, for instance, I do not see a change in the drivetrain angle.
  #19 (permalink)
Old 10-07-2011, 09:18 AM
I agree, tire size has no effect on driveline angles. Axle to frame height, or axle to crankshaft centerline height does however. You should shoot for having the crankshaft, and axle pinion parallel. The height will determine your u-jount angles which are typically in the 2-4 degree range.
I also don't think the OP's angles can be 20 degrees. I trigged it out with a 55 inch long driveshaft at 20 degrees, that would give a height difference from crankshaft centerline to axle of almost 19 inches. Unless he has a monster truck I don't see how the angle can be that severe. Or if either the engine or the axle is mounted at a very severe angle.
Edit: Not sure why, but I don't see the picture either
  #20 (permalink)
Old 10-07-2011, 09:20 AM
Frisco's Avatar
Glad To Be Here
I thought about drawing examples out but that would take too long.
So I did a quick search for pics to illustrate. Below is a pic of a rock crawler and a monster truck. Notice that in both pics the engines are installed at what appears to be the 'normal' 3 degree down at the rear angle. Next look at the driveshaft angles.
If the engines were installed lower in the frames of either vehicle at the same angles that they are now, the driveshaft angle would be much less than shown.
Also if the rear axles were installed higher up in relation to the frame, the driveshaft angles would be reduced.
As to the tire diameter statement I made, if the body was kept at the same relationship to the ground as shown, but the tire diameter was either reduced or increased, the suspension would have to be modified. That modification would cause the driveshaft angle to change.
The same is correct if the wheelbase is shortened or lengthened. If all else remains the same the driveshaft angle will change.
The pics I posted are of vehicles that are not driven great distances at high speeds. This enables the radical u-joint angles to function (sort of) but they will not last long because of the extreme angles.
ID:	58831   Click image for larger version
Name:	monster truck.jpg.jpg
  #21 (permalink)
Old 10-07-2011, 09:26 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the suspension was modified, that could change the DT angle- what I am saying is a change in tire diameter will not change the DT angle. Agreed?
  #22 (permalink)
Old 10-07-2011, 09:30 AM
Frisco's Avatar
Glad To Be Here
YES. With all other things being unchanged, just changing the tire diameter will NOT change the driveline angle.
  #23 (permalink)
Old 10-07-2011, 09:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Ok, I got it, thanks.
OT- whose wheels are those (brand), on the '32(?) in your avatar, and do you like them, good chrome, any probs. w/them? I'd like a set for my wagon.
Am I the only one who can't see it?
  #24 (permalink)
Old 10-07-2011, 09:45 AM
Frisco's Avatar
Glad To Be Here
I can't see the photo either. It's not attached to the post.
The chrome wheels on the '28 Ford Pickup were purchased thru Coker in Chattanooga. I'm not sure who they got them from. Excellent chrome and no problems with them.
  #25 (permalink)
Old 10-07-2011, 09:56 AM
Bobs36ford's Avatar
u joint angle
See 2nd attachment
  #26 (permalink)
Old 10-07-2011, 11:22 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That looks like a lot to me... But 20 degrees? In any event, I believe dropping the front of the engine will help if it's nose-up (what is the attitude of the engine in the frame?), possibly also lowering the engine if it can be done w/o major surgery.
  #27 (permalink)
Old 10-07-2011, 12:07 PM
prostreet6t9's Avatar
Differential/Driveline
I would raise the rear up a little. Take a 1/2" of washers and put them in between the trans mount and the trans with the mount bolts going thru the washers. Run the car on jack stands and see if it helps any. You can experiment with the thickness to see if you can make the shake better or worse.
If you find a spot that makes it better you can make a aluminum spacer with the thickness that worked best.
Its hard to tell by the pic... Depending on how long that slip yoke is,it almost looks like the D/L may be a little short.
If you get a chance you might post a pic of the rear angle also.
  #28 (permalink)
Old 10-07-2011, 12:38 PM
engine and driveshaft angle
2-5 degrees on drive shaft with engine intake level bubble left to right front to back for float level
  #29 (permalink)
Old 10-07-2011, 03:01 PM
Bobs36ford's Avatar
u joint angle
Rear u joint angle
  #30 (permalink)
Old 10-07-2011, 03:09 PM
Bobs36ford's Avatar
Thanks for the info. I just posted pic of rear u joint
Vibration 1Sick 32 Transmission - Rearend 33 09-27-2008 10:29 AM
Transmission vibration ArmyofOne Transmission - Rearend 3 11-28-2007 04:30 AM
350 vibration caminoguy55 Engine 15 01-28-2004 09:10 AM
vibration dankarol Engine 4 12-24-2003 11:15 PM
Vibration markiemyster Engine 4 07-11-2003 09:05 PM
