Transmission Want Shift Into Overdrive - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2005, 03:41 PM
I Have A 1983 Pontiac Grand Prix That I Put A Chevy 350 In. I Did Away With All The Computer Stuff, New Carb, New Electronic Int.now The Transmission Want Go Into Overdrive, Can Some One Tell Me How To Wire It Up To Work With Out The C.p. Hooked Up
Old 06-08-2005, 03:54 PM
MI2600's Avatar
Member# 3287
Does "want" = will not? or won't?
Old 06-08-2005, 04:35 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what tranny is in the car?
Over drive was not computer controlled/shifted in that year of vehicle.
Is it possible you have a lock up t-350C and think that is over drive when the converter locks up?
Old 06-08-2005, 04:40 PM
It is a t350c
Old 06-08-2005, 05:02 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that tranny is not an over drive unit.
you could do some mods to have the lock up work with a governor pressure switch. Depending on the valve body design it's Not simple for the DIY person
Originally Posted by butchs18
It is a t350c
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 11:59 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
Transmission won't shift into overdrive Scuzzy Transmission - Rearend 3 09-27-2003 08:20 PM
Jeep Transmission Shift Question F-1Rodder Transmission - Rearend 1 02-05-2003 01:24 AM
Overdrive transmission merkery Transmission - Rearend 1 06-25-2002 09:25 PM
