-   -   Transmission wiring on 700R4 (http://www.hotrodders.com/forum/transmission-wiring-700r4-217903.html)
jerry nance 04-07-2012 02:12 PM
Hi, I have an 86 Chevy Silverado and the plug for the transmission (the 700R4) got cut off. I have been looking for one. I found a 1989 Surburban with the plug. The color codes are not the same. My wiring harness has two greens and a blue wire and the one I found at the yard has a blue, yellow and a brown w/a black streak. I would like to know how to hook this wire into my wires to get the color right to make my locking converter work.
Jerry Nance
SSedan64 04-07-2012 08:21 PM
Jerry Nance
AutoZone has wiring diagrams, you have to sign up to view them.
The Blue is 12V+ from the brake switch, Greens are probably 4th Pr. switch & -Ground from ECM or 3rd Pr. switch.
These may help:
http://www.hughesperformance.com/pdfs/HP700-R4.pdf
http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
