Transmission wiring on 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2012, 01:12 PM
Hi, I have an 86 Chevy Silverado and the plug for the transmission (the 700R4) got cut off. I have been looking for one. I found a 1989 Surburban with the plug. The color codes are not the same. My wiring harness has two greens and a blue wire and the one I found at the yard has a blue, yellow and a brown w/a black streak. I would like to know how to hook this wire into my wires to get the color right to make my locking converter work.
Jerry Nance
Old 04-07-2012, 07:21 PM
SSedan64's Avatar
Jerry Nance
AutoZone has wiring diagrams, you have to sign up to view them.
The Blue is 12V+ from the brake switch, Greens are probably 4th Pr. switch & -Ground from ECM or 3rd Pr. switch.
These may help:
http://www.hughesperformance.com/pdfs/HP700-R4.pdf
http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
Need 700R4 transmission help lamothe1 Transmission - Rearend 7 07-29-2011 11:50 AM
wiring for torque convertor lockup on 700R4 transmission skyraker Transmission - Rearend 4 07-01-2011 10:19 PM
700r4 wiring?? 75GMCman Transmission - Rearend 6 01-21-2009 10:44 AM
Need help wiring my 700r4 409guru Transmission - Rearend 3 01-21-2008 02:02 PM
700R4 wiring? DirtyDoug Transmission - Rearend 9 12-30-2004 09:04 PM
