Transmission wont shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2006, 06:18 PM
74chevy454's Avatar
Last journal entry: 74 Chevy Cheyenne Super Custom Deluxe
Hey all ,
Hope someone can help, I have a chevy 74 custom deluxe c20 p/u. I just rebuilt the 454 to make it a 468 and while I was rebuilding the engine I had a buddy do a b&m shift kit on it just one step on it the tranny is a turbo 400. Before the engine spun a rod bearing the tranny was fine. I took out the engine and tranny did the rebuilt and put them back in trying to fine tune the engine and went for a drive for the first time and it doesnt seem to shift. I changed the vacuum modulator to a B&m instaed a stock one but still feels like its not shifting so tonite after wife gets home I am going to go out and check vacuum and mess with it.(scratching head) Hope I can fix it or someone can help me. Or point me right direction. I hope buddy didnt do something wrong on shift kit,Should have done that myself so I know or blame myself if its messed up.......heheheh Thanks all. Vinny
Old 08-12-2006, 09:21 PM
scrot's Avatar
I'd get the B&M instructions and look over the work "your buddy" did: a missplaced checkball here or a lost spring there will mess you up real good. Some vacuum modulators use a rod between it and the trans. If your does, see if it is installed. Oh, yea, ask "your buddy" if he had any parts leftover.
Old 08-19-2006, 02:43 AM
74chevy454's Avatar
test drive and talked to friend
Ok test drove it again today and it wint shift into second at all works fine in reverse and 1st but no shift have vacuum and replaced modulator with b&m one. And buddy that did it was with another one of my friends say same thing nothing left over and the book I bought and shift kit instuctions say it might to have to do with the governor or governor tubes..... we will find out going to take it apart and look.
Ford 4R70W Transmission won't shift 2-3 Arrowhead Transmission - Rearend 2 04-30-2006 05:22 PM
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 11:59 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
transmission shift too early? CurtisL Transmission - Rearend 4 11-05-2003 11:41 AM
Transmission will not shift. sylliaaa Transmission - Rearend 3 08-28-2003 05:38 PM
