Transmissions that bolt to a 2.2L chevy S-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2011, 06:59 AM
Hello, I am new to this site and this is my first post. I was wondering what transmissions would bolt up to a 2.2L chevy S-10. I searched the net an could not find the information I was looking for. Thank your for your time, advice, and knowledge in advance.
Old 12-03-2011, 07:40 AM
SSedan64's Avatar
I'm thinking this has the 60* Degree Bellhousing pattern so 700R4/4L60/4L60E & T5 with 60* pattern Bellhousing.
Old 12-03-2011, 07:55 AM
I think I did read that it has the 60 * degree bellhousing, but I wasnt sure what type of transmissions had this same pattern. Thank you for your reply.
Old 12-03-2011, 08:05 AM
SSedan64's Avatar
Those can also be found behind 2.8, 3.1 & 3.4L 60*/V6 engines.
Old 12-03-2011, 08:10 AM
thank you for the advice. this is gonna be my first " project " i guess you can say, though i've helped more then a few friends with things on their vehicles. my initial plan for it as far as performance wise is to keep the original 4 cylinder thats in it instead of swapping it for a V-8, the reasons im doing that are because EVERYBODY swaps V-8's into them and I wanted to be different and off set that, im also going to see how far i can push that little 4 cylinder. I plan on doing as much as i can myself, mainly for learning an experience 'cause you can never really learn to much or have enough experience under your belt. again, thank you for the advice and knowledge.
I'm not sure which direction i want to go with it as far as how im going to build the 4 cylinder but i wanted to know my options as far as transmissions go.
what to do to change a 6 bolt lug to a 5 bolt lug pattern?(chevy) uneeksparke Transmission - Rearend 4 06-12-2011 05:10 PM
Auto transmissions that will bolt up to a 283 88lowrider Transmission - Rearend 8 07-14-2008 09:06 PM
1940 Chevy Coupe Transmissions canyonclimber Transmission - Rearend 5 11-06-2006 10:32 PM
Swapping Chevy 10 bolt to a Pontiac 12 bolt? 406chevelle Transmission - Rearend 4 03-26-2004 10:37 AM
