transmisson
I built a hot rod motor and got a 3500 stall chevy torque converter
And when I pulled out of the drive my transmisson would not take gears when I had the other motor in it it was taking gears good it is a modified 350 4-bolt with 500hp chevy. Last edited by bad2be; 07-01-2006 at 07:54 PM. Reason: need more info |
Take gears?? What does this mean?
If you are refering to shift quality, high stall converters will make the trans feel soft on upshift when you are below stall speed. Gear ratio? Tire size? Cam grind specs? |
transmisson
It is not going in any gears at all
can some one tell me why I know the cam specs are right and the gear ratio it is not soft shift quality it want go in any gear it will not move at all. Last edited by bad2be; 07-02-2006 at 09:53 AM. Reason: need more info |
transmisson
do you think it burnt the transmisson or something simple
I'd say a pump failure. Did you install the torque converter dry? Either that or your shifter lever fell off. |
| Gear / Transmisson question | timothy9972 | Transmission - Rearend | 1 | 05-09-2006 05:16 AM |
| transmisson | Kevin Lowe | Transmission - Rearend | 1 | 04-10-2006 08:35 PM |
| Transmisson Problems | PontiacRacing1994 | General Rodding Tech | 2 | 09-18-2003 08:31 AM |
| Transmission | knumbskull | Transmission - Rearend | 5 | 08-12-2003 11:34 AM |
| calling all transmisson gurus | igotachevyor2 | Transmission - Rearend | 3 | 04-15-2002 04:48 PM |
