Transplanting a TBI 350 in a 69 Chev PU - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2011, 03:02 PM
I'm installing a TBI 350 with 700R4 into my 69 Chev PU. The donor car was a 93 Buick Roadmaster. It's what they call the LO-5 engine. Everything fits fine, but I'm wondering how much of the electronics and emissions equipment I will need to use to have the engine/transmission work properly. I've got the PCM from the donor car and all of the wiring and emission equipment, but don't want to install what I don't need.
Passing emissions is not an issue due to the age, although I don't want to foul the air either.
Old 11-27-2011, 06:00 PM
LATECH's Avatar
I would run everything right down to cat converters.All the electronics, properly installed will keep it running clean , fuel efficient and with the best possible performance. Oh ...you could get way more performance from it , but with the original electronics gives you a good mix of power and economy.
The the port injection and the 4 speed automatic gives pretty decnt performance,and the lockup converter provides the best possible mileage.
I have seen a lot of those engines in the roadmaster and a few cadillacs also. Often wanted to do something very similar to what you are doing.
The wiring is a lot of fun, I love to do wiring betterthan most anything else.
Some people dread wiring, makes it better for me.
Old 11-27-2011, 06:44 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
What are you doing about a drive shaft and tranny cross member? The cross members are off the shelf,,,, but the shafts can break the bank If it is a long box then getting a one piece shaft made is a real stretch )---------) Hard to have a custom one done right. Go with two piece
http://www.dennysdriveshaft.com/c52_..._72_truck.html
I agree with Latech use every sensor/gizmo's associated with the OEM unit. Look for detailed wiring diagrams and definition manuals. Wish I knew more about the engine management system requirements,,,maybe someday
Old 11-27-2011, 08:52 PM
TBI transplant
Thank you both for your input.
Latech, I really like your GTO. My first car was a 64 Le Mans post. My first restoration was a 67 Firebird conv. Not too crazy about needing a cat. I wanted to put duals on the truck. I was hoping that with the throttle body, I wouldn't need so much of the old equipment.
Custom 10, I got the trans mount from Classic Performance. It looks like the driveshaft from the Roadmaster is just slightly too short, about an inch or so. I'm not sure if I will get in deep enough into the tailshaft to be safe. I had a new driveshaft built for my 58 Apache a couple of years ago. Seems like it was about $200. Did a good job so if the old one won't work, I'm counting on seeing the same guy.
Old 11-27-2011, 09:19 PM
Last journal entry: Paint
Does that engine use the bigger TBI? The Caprice police cars of that era used the cam from the TPI.
Old 11-28-2011, 10:29 AM
You need to check the transmission very carefully to see if it is the mechanically controlled 400R4/4L60 or is the electronically controlled 4L60E, the 93 Buick is right inside the transition period. In either case the transmission is set up for an electronic speedometer, you will either have to back date to a mechanical speedometer drive or change out the 69's mechanical for an electronic speedo. You will also need the electric in tank fuel pump if you're planning on running the TBI, or even a carb as this engine probably doesn't have the mechanical fuel pump provisions machined into the block, just the raw casting location, if that.
The LO5 engine is the Swirl Port engine mostly used in trucks, it is not known for anything approaching performance. It doesn't take much in the way of changes to the engine, especially camshaft, before you run into needing a custom blown PROM chip in the computer and a little beyond that you run out of sensor sensitivity to changes. About the limit on cam is 200 degrees on the intake and 215 on the exhaust with about a 112 degree LSA as overlap has to be eliminated or manifold vacuum will fall below sensor capabilities to discriminate small changes in vacuum that make large changes in fuel requirements that happen with bigger cams. As it comes from the factory there is a lot of vacuum that is used to discriminate small changes in fueling, so the sensors are designed around this insensitivity range. As the cam gets bigger the vacuum drops while the fueling sensitivity to small changes becomes much greater, this is simply outside the range of OEM sensors. This engine can be taken to about 280 hp with original components and a custom chip. To move beyond that point is possible you can take it to 300 maybe 330 but it takes a lot of electronic changes, much larger injectors, and a very sensitive hand at the set up.
If the tranny is indeed a 700R4/4L60 it may well be a lot simpler to carb the engine.
Bogie
Old 11-28-2011, 04:46 PM
350 Tbi Transplant
V8 & 4spd--How would I tell if this has the larger bores? What would the dimensions be?
Old Bogie: The only electrical connection is on the tail shaft so I am thinking this was still non-computer controlled. I've got a rebuilt quadrajet that I could use. I would just need to purchase a new manifold. I know that TBI is not the greatest fuel-injection system, but I sure don't mind getting away from a carb if it's feasible.
Old 11-28-2011, 05:25 PM
I don't know on the TBI, I see them for sale on Ebay. I had one of the Caprice police car engines but it was missing the TBI. I found a post somewhere that said the cam was the one they used in the TPI engine. I looked up the numbers on the cam and they matched the TPI cam.
Old 11-28-2011, 06:49 PM
They are selling TBIs on ebay that claim a bolt on 45hp increase. They also sell TBI engines that claim to be 310hp. They also sell a wiring harness for a TBI for $225.00.
Old 11-28-2011, 07:32 PM
That would be the electronic speedometer data source.
Bogie
Early Chev/oller Cam Chev Differences belairheaven Engine 1 08-14-2010 08:31 AM
Early Chev/roller Cam Chev Differences belairheaven Engine 4 08-14-2010 05:59 AM
Transplanting LS1 in my el camino 71 el camino Engine 2 06-04-2004 02:48 AM
Has anybody used a Chev Astro van booster/master cylinder for the 48 chev truck tomy2tone01 Suspension - Brakes - Steering 2 04-07-2003 05:05 PM
Installing a chev small block in the rear of an chev s-10 vegadeth Body - Exterior 11 07-16-2002 03:16 PM
