Tread looping under the piece i sew...
Hi!I just bought a use green consew 255 rb3,it was working perfectly until it brooke a needle.Now tread is looping heavily under the piece of leather i'm sewing.What should i do.I was tinking that i did not retread correctly.How can i correct this problem,sewing was not part of my job that i just retreat from...Thank you...Normand...
Welcome to the site. If you ask you question in the interior section someone will come along and help you out. Not everyone checks the Introsection.
Cole |
Did you put the new needle back in correctly, and did you use the correct needle for your machine? The correct needle is a 135X17. The needle needs to be installed as high up in the needle bar as possible with the scarf to the right and the groove to the left. It also sounds like your top tension may be too loose, which means you may not have re-threaded the machine correctly through the upper tension disks. Check out post #4 in this thread to see how your machine should be threaded: CLICK HERE
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 02-24-2011 at 02:18 AM. |
| Recent Interior posts with photos |
| Question on tread width. | impalaman63 | Suspension - Brakes - Steering | 16 | 02-25-2013 04:37 PM |
| tread sealer | Houman SS '70 | Hotrodding Basics | 10 | 03-20-2005 03:12 PM |
| need some input on ford one piece to two piece seal conversion | 357ford | Engine | 6 | 10-08-2004 10:51 AM |
| Actual tread width?? | ets1945 | Hotrodders' Lounge | 3 | 12-26-2003 03:07 PM |
| front tread 58 inches | chevyist | Suspension - Brakes - Steering | 2 | 02-12-2003 05:24 PM |
