tremec t56, 400lb ft + truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2005, 05:45 PM
ScotRod's Avatar
New Member
I am looking into an overdrive transmission for my 1970 F100. The Truck weighs in at 4300lb, and is running 3.55 rear gears in a 9 inch diff. I rebuilt a 351w for it and it is pulling about 350 hp, 400lbft of torque. I plan to add a supercharger in the spring and put in some bigger valves to pull it into the 500+ lb ft range. I have been looking at the "TREMEC 5-SPEED EXTRA HD TRANSMISSION" pt # M-7003-R58C* that Ford racing sells. They say it will handle 600lb ft of torque. I am worried that my truck is too heavy and the trannny wont last especially if I add a posi. Has anybody run this tranny or know what it can handle on the street?
Old 10-18-2005, 07:57 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I think your biggest problem will be traction.
If you don't hook it up in the low gears, it won't matter.
Those transmissions are probably rated for "solid traction" at that torque level.
I'd contact the transmission manufacturer.
94 chevy truck runnin' like poo! bluesmanjesse Engine 11 11-09-2006 03:54 PM
Ebay Truck Headache CrashFarmer2 Hotrodders' Lounge 8 09-06-2003 08:30 PM
