tri bar light streetrod headlights - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2013, 11:54 AM
jbranontn's Avatar
Has anyone bought and used the Tri Bar Streetrod headlights sold on Ebay...if do, are the brighter than regular, sealed beam headlights? Any reviews on these?.
Old 03-26-2013, 01:22 PM
302 Z28's Avatar
I tried them briefly on my 34, didn't like em. Went back to standard quartz halogen. Also wied my halogen headlamps them with relays which made them a lot brighter than standard installation.
Vince
Old 03-26-2013, 02:44 PM
33Willys77's Avatar
I dont think they are any brighter - but should be the replaceable bulb (H4?). The tri-bar is there for looks - and you can put signal light kits in them too. You can also search and get brighter bulbs, some are 100W high beams - those are brighter.
Old 03-26-2013, 11:51 PM
Have them too and they're there for looks rather than function.
Old 03-27-2013, 07:46 PM
302 Z28's Avatar
I would not go with the signal light kits. I was at a stop light not too long ago and a fellow rodder was across the intersectiion in the turn lane. His lights were on and I could not see his turn signal at all.
Turn signals are better off somewhere else IMHO.
Vince
Old 03-28-2013, 04:26 AM
Banned
Vince
THIS^^^
I have a bulb set up for my truck that uses the h4 bulb.. it's a little brighter, but thats from compare'n them to non halog bulbs..
like said above, wire'n the lights with a relay feeding them makes a HUGE difference.. in my truck the headlights got 11.9 volts with the power going the way the factory did it (battery /cab/switch/headlights)
now the switch only is the relay trigger and the lights get 14.5 volts when running and 13.4 when off the battery..
Tri-Bar Headights PopcornJim Body - Exterior 4 01-29-2008 02:55 PM
Tri bar headlights genr8rs Body - Exterior 3 06-06-2006 01:46 PM
tri-angulated 4 bar or? el paradiso Suspension - Brakes - Steering 4 01-29-2006 08:25 PM
Tri bar headlights americanLT1 General Rodding Tech 2 12-22-2004 08:35 PM
Tri bar headlite Nigel Electrical 2 11-14-2002 03:29 PM
