Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tri carb help
Thread: tri carb help
Old 09-18-2008, 02:28 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
It's a legitimate tripower setup, no accelerator pumps on the outboard carbs? Cam you being those carbs in sooner and see how that works? You may have a ton of timing coming in early, what's the timing when they start to open? Unless you're accelerating hard, if you have fuel in the bowls free revving it, you're not going to starve it for that split second while transitioning.
Semper Fi
