Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tri carb help
Thread: tri carb help
Old 09-18-2008, 02:37 PM
kbyounger kbyounger is offline
OK, no its not a real tri power set up, the outside carbs have been altered to make it "tri power." The only thing I know about timing is that the engine is set at 7% advanced, but I don't have the knowledge or tools to watch the timing during acceleration... someone mentioned that perhaps bringing the carbs in later, would help, because it sounds like it is running lean... I can certainly play around with where the carbs come in at, and if that does not take care of it, then I suppose I could then check the float levels... any other thoughts? thanks - kip
