tri carb help
I finally got my three deuces on, connected and running!!!! But, when I rev the engine to the point that the secondaries open, the center carb will Pop or backfire as they first open. If I rev it slowly to the point of where the secondaries will begin to open, then the engine "bogs down - or hesitates. I have heard that the floats in the fuel bowls must be set exactly right or the secondary carbs can be too lean or rich... Is this what would cause the center to backfire? Any ideas are greatly appreciated. I'm so close to getting these things running... thanks - kip
It's a legitimate tripower setup, no accelerator pumps on the outboard carbs? Cam you being those carbs in sooner and see how that works? You may have a ton of timing coming in early, what's the timing when they start to open? Unless you're accelerating hard, if you have fuel in the bowls free revving it, you're not going to starve it for that split second while transitioning.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
OK, no its not a real tri power set up, the outside carbs have been altered to make it "tri power." The only thing I know about timing is that the engine is set at 7% advanced, but I don't have the knowledge or tools to watch the timing during acceleration... someone mentioned that perhaps bringing the carbs in later, would help, because it sounds like it is running lean... I can certainly play around with where the carbs come in at, and if that does not take care of it, then I suppose I could then check the float levels... any other thoughts? thanks - kip
It does sound like a lean condition, so try bringing the end carbs in sooner, not later.
| Quadrajet Carb??????? | zbhover | Engine | 15 | 08-26-2010 08:57 AM |
| backfire thru carb | airraptor | Engine | 11 | 06-12-2009 02:30 PM |
| Holley Carb. Question | crusherdbuzz | Engine | 2 | 07-02-2006 03:25 PM |
| Cleaning Carb Question | oldcarguy36 | Engine | 17 | 03-04-2006 02:10 PM |
| Holley carb has me at wit's end | cool rockin daddy | Engine | 23 | 06-02-2005 02:38 PM |
