Tri Power and 700R4 set up help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2006, 01:39 PM
Not A T 25's Avatar
Takes Guts To Cut One Up
I am still trying to find the best way to set up a 700R4 with my Tri Power intake there is not an after market linkage available for my Stromberg WW carbs but the linkage point for the TV cable on my carb seems to come very close to matching what I have seen in some post 11/8" from shaft center and a 78 deg arc to WOT I am using an after market TV cable which is not self adjusting. Should I just use the WOT full cable setting or the transmission pressure at Idol and WOT? If the pressure method is best what range should I be in. I called Mad Dog and ask them and they just want full cable extension at WOT but with my application I don't feel to safe with that I really don't want to trash this $1200 transmission. I have new engine trans and posi section so want all to be right. Any help or suggestions would be appreciated.
Success is getting what you want but happyness is liking what you get.
Old 06-06-2006, 06:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
visit this page
clik here
photos show geometry needed for what you are building.
hope this helps, good luck , have fun!
Old 06-06-2006, 08:30 PM
Not A T 25's Avatar
Originally Posted by Crosley
visit this page
clik here
Thanks for the link am I off base thinking I should verify the pressures?
Old 06-06-2006, 08:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
nope....... lets not be anal about them neither.
this 700 tranny needs a good pressure rise ( rapid) , not a slow rise as the TV is pulled quickly as if you stomped the LOUD pedal
Bbc Tri Power crossfire84 Engine 5 07-20-2012 01:21 AM
big power loss at 4 g's only in 3rd gear (700r4) mason71 Transmission - Rearend 4 03-26-2005 10:32 AM
700R4 and Dual Quads Or Tri Power zonk Transmission - Rearend 1 03-13-2005 07:35 AM
700r4 power question?? traub83 Transmission - Rearend 2 05-22-2004 07:37 PM
What is the most power someone is running with a stock 700r4? swoodard23 Engine 0 01-19-2003 04:48 PM
